One piece of caution - I doubt you will need to change the lower wood piece in the centre console around the gearshift, but if you do need to then the wood trim must be from an early SEC (pre 86). The early SEC wood trim have switches which slot in from above the wood. The late SEC's have switches that slot in from beneath - so the cut-out is different in the wood. You cannot interchange switches, since the switch housings are completely different.
That's the only thing you really need to be aware off.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
