How come some ppl can't see the vid?That's what it sounds like.
I can't see the video either. The half gear thing you describe is the TC lock up clutch operating, and is normal. If you have a known ABS sensor fault I'd get that fixed first, as they can make the gearbox behave strangely. I'd also check your tyre sizes are correct, as mismatched rolling diameters will cause similar problems. You describe noise in the box when spinning the wheels in neutral, presumably with the engine off. This worries me a bit. I'd expect to hear some noise as there is a fair bit of stuff going round. Hard to say if what you are hearing is normal or not. The most common thing I have replaced is the torque converter. These give a funny gearchange when knackered. Each change has a judder following it, a bit like a cattle grid noise, but more gentle.
NoCan you see it now
No. The park pawl operates on the output shaft so would not make a noise when the car is stationary.Could have something to do with the selector unit on the side of the box like the park pin is not retracting properly
That would be easy to pin point where the noise is coming from, nothing would be spinning at the rear of box?Could have something to do with the selector unit on the side of the box like the park pin is not retracting properly
Hahahahanoise at 54 seconds sound like the ISM where you are changing gear with the column switch and is 100% normal !!!
3 or so ticks around 5 seconds no idea
the rear clunking about on full on abuse is normal, its the diff bushes slightly worn.... 4 years on mine never makes the sound as it only does it under extreme abuse when the TC is arguing with 386 bhp and first gear with warm tyre and dry tarmac
the TC falls to bits. a standard Merc feature and the elecro plate is also DTF
trusting this car with a garage that does Lamborghini's, is about at much good as taking it to some guy who last worked on a 1979 Skoda rapide with a 12v test light
there will be codes his 15 quid kit just doesn't know what they are
