Idiot Alert - Idle car.
Discussion in 'General Mercedes-Benz Related Discussion' started by Unsound Methods, Jun 12, 2019.
  1. Unsound Methods
    Unsound Methods Senior Member
    66
    Dec 20, 2013
    London
    Your Mercedes:
    Mercedes 300SL-24 1991
    Morning all.
    Ive been away and the weather is a bit rubbish at the moment, and Ive not had my 91' 300SL-24 out of the garage for a couple of weeks, so i decided to start the car up for 15 minutes (as per a mechanics advice on not using a car through the winter) to give the battery a boost.
    So start her up and waddle off to do some other bits, 45 minutes later i remember the car is still running. duh ...
    I nelected to check the temp dial, and the car has cooled down considerably. but theres no smoke or terrible 'burnt to failure' smell so im assuming/hoping ive not done any damage? I'm guessing its not entirely a good thing leaving it running for that long?
    Could I have done any damage or is 45 minutes nothing in the grand scheme of things?
    cheers
    Dani
  2. Naraic
    Naraic Moderator
    10,049
    725
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
  3. OP
    Unsound Methods
    66
    Dec 20, 2013
    London
    Your Mercedes:
    I do like an unambiguous answer! ;)
    thankyou Naraic!
    Naraic likes this.
  4. JDPEClassUK
    JDPEClassUK Member
    24
    14
    Sep 29, 2018
    Your Mercedes:
    E Class Estate E220d (2019)
    I agree - no damage, but would be good to give it a run to clear any coking caused by long idle running for 45 mins.
    Unsound Methods likes this.
  5. RhodiBill
    RhodiBill Senior Member
    250
    172
    Jan 30, 2019
    Central South Coast of England
    Your Mercedes:
    Mercedes 2003 w203 C180K-SE Sports Coupe.
    No - None - Nada....
    NB. But the only thing I do do if I do this is to leave the window open just in case the car decides to lock itself for some strange reason.... ;)
    Jimbo1959 and Unsound Methods like this.
  6. MalcQV
    MalcQV Senior Member
    236
    66
    May 4, 2017
    Manchester
    Your Mercedes:
    Mercedes CLA200
    I store both my 360 (in a garage) and recently my Z3 (outside with a cover) and on battery conditioners in the winter months and only start them if I need them moving. When I do run them I do so for at least 25-30 minutes so as everything gets warm. Ultimately the most engine wear occurs prior to getting to temp. So whilst idling warms the car it does so slowly and causes more wear.
    This is why today the owner's manual tells you to start the car and go, not to idle. It warms up quicker and therefore less wear.
    There's lots of contradicting information on storing cars both long and short term (I call winter storage short term) regarding running the engine to push oil round (obviously good) down to cold temperatures leading to high fuel content (choke) and bore wash causing none lubrication (bad). You take your pick :D
    All that said tolerances on newer engines are tighter and on an older design it possibly does not apply the same. Either way 45 minutes IMHO is probably actually better than 15 so long as it does not overheat. In future i would say about 25 minutes is best.
    Better still if you can actually drive it then that is the best.
  7. OP
    Unsound Methods
    66
    Dec 20, 2013
    London
    Your Mercedes:
    thanks MalcQV, thats muxh appreciated. What battery conditioners do you use? perhaps that might be an option worth considering.
  8. Uncle Benz
    Uncle Benz Senior Member
    2,474
    663
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    45 minutes? Provided the cooling fan works it's fine. Embarassing incident, some years ago I was closing up the workshop and I had to bring an S500 in from the lane into our secure compound. The battery sounded low, so I parked it and left it running while I brought the other cars in and locked the workshop.
    The next morning I was opening up and I thought "I can hear an engine running, whisper quiet but something definitely idling". Yup, I'd left it running all night. On the plus side the battery was fully charged.
  9. umblecumbuz
    umblecumbuz Senior Member
    3,520
    855
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    Smart battery charger/conditioner?
    C-Tek seems favourite, but there are several similar on the market now for a lot less money. I paid around £30 for mine. My friends now use it almost as much as I do!
    rorywquin and Unsound Methods like this.
  10. EmilysDad
    EmilysDad Senior Member
    7,242
    1,241
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Ooops! :rolleyes:
  11. daibevan
    daibevan Senior Member
    948
    511
    Sep 29, 2015
    Plymouth
    Your Mercedes:
    W203 C200 Kompressor Elegance SE 2006
    Did you top up the fuel? ;);)
  12. Uncle Benz
    2,474
    663
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    It had used a fair bit as I recall, but it didn't run out
    daibevan likes this.
  13. rorywquin
    rorywquin Senior Member
    1,320
    645
    Dec 28, 2016
    North Yorkshire
    Your Mercedes:
    2017 SL400 AMG Line
    Wouldn't it be better to take the car for a run on a nice day and get everything moving?
    I don't believe that 15 minutes of idling will even put back the energy used to start the car.........and if your alternator is not functioning properly, you could possibly be running the battery even flatter.
    The other danger is exhaust fumes (if car does not have a cat converter, you are also getting a garage full of carbon monoxide).
  14. OP
    Unsound Methods
    66
    Dec 20, 2013
    London
    Your Mercedes:
    We havent had " a nice day" for almost 2 weeks. ;) - normally this time of year i'd be using it all the time but weather and work have curtailed that a bit. unfortunately the stitching is coming undone around the soft-top window so it isnt water tight at present, so i dont take it out if theres any chance of rain - at the moment there little chance of anything else it seems...
    It seems to do the trick over the winter months when i dont use it. It fires up very quickly if i run it for 15 (or so) minutes every week or two. But I am considering a charger for next winter.
    rorywquin likes this.
  15. MalcQV
    236
    66
    May 4, 2017
    Manchester
    Your Mercedes:
    Mercedes CLA200
  16. Capra
    Capra Senior Member
    2,851
    884
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    W204 2013 C350 CDI Pan roof
    Are there any dangers of running a car at idle overnight?
  17. Uncle Benz
    2,474
    663
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    Well it isn't something I would generally do! Plenty of risks. It could have overheated, caught fire and burned to the ground. Luckily I got away with it, and I have been careful not to repeat the mistake. I'm wishing I hadn't mentioned it now!
    Capra and LostKiwi like this.
  18. LostKiwi
    LostKiwi Senior Member
    17,632
    8,015
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
  19. stwat
    stwat Senior Member
    1,661
    71
    Jul 20, 2004
    Sheffield
    Your Mercedes:
    1989 300SE
    It also promotes moisture build up in the oil and breather systems.
  20. RhodiBill
    250
    172
    Jan 30, 2019
    Your Mercedes:
    I can well understand what you did because they are whisper quiet. If mine is idling from only a couple of metres away I cannot tell if the engine is running. Even inside I occasionally look at the Rev Counter because I think it has stalled for some reason - but it hasn't....
    So if you forget you've left it running there is no audible warning letting you know you have!
Share This Page
