Idiot question about lubricating throttle linkages
jeremy156
Bordon, UK
W202 C200 (1999)
I wish to lubricate the various linkages that form the throttle control on my M104, having realised no benefit at all from replacing the throttle cable.
I read that I should use ATF in the ball sockets and the pivots.... just wondering whether power steering fluid would be the same, as I have some of that.... or whether I should get hold of ATF anyway...? ... or is there something more appropriate, such as moly grease in the ball joints?
jeremy156
jeremy156
Bordon, UK
W202 C200 (1999)
Thanks Alastair
ajlsl600
france
when there is a clip holding the ball i use a small amount of grease ,when not if the cable goes down and away ,a little 3 in 1 if up nothing, its a compromise between lube and attracting dirt/grime and making a grinding paste.
