Chop 'N' Join
- Oct 18, 2006
According to the manual the Voltage at the Idle Control Valve should be 5Volts +or- 1Volt. (380SEC - 1983 UK Version)
I have 4.4Volts so this is within the accepted level.
I don't know the maximum voltage the Idle Control Unit can output to the Idle Control Valve, I would presume it is 5Volts +or- 1Volt.
Perhaps someone could confirm this.
Thank You
Thank You
