Idle Control Valve or Crank Position Sensor?
lepton
Mid Sussex
I have a 1990 300SE Auto which has hot stalling problems similar to those reported elsewhere on the forum. The car runs very smoothly when cold or at speed when the temperature is about 78 C, but when standing at lights etc in Drive, the idle revs which are usually very steady at about 700 swing between 450 and 1200. The revs drop back to a steady 700 if the car is slipped into neutral. I have replaced the OVP, fuel filter, the thermostat and the coolant to no effect. Previous threads suggest the problem could be related to a sticking Idle Control Valve or a faulty Crank Position Sensor
(£104). Which is more likely to be the culprit?
Any help appreciated,
Alan
