ignition barrel
robparker
Taunton
today i got back in my 230ce w124 and i couldnt turn the ignition key, the steering lock wasnt even engaged.. afetr 30 secs of wiggling i got it to turn. it hasnt done it before and when i got home i took the key out and tested it and it was ok the few times i tried. is it best to replace it straight away? and any ideas how much that would be? thanks alot
One cure, and it sometimes works is white lock grease, from a lock smith or MB. MB say it is always worth a try before replacing the lock or key. Do not use anything else.
Malcolm
robparker
robparker
Taunton
and do what with it exactly.. smother it on the key and apply it that way?? thanks
That right,and you do it a few times, I use hypodemic needle to inject it. if you know someone with diabetes, ask them for an old needle.
malcolm
robparker
robparker
Taunton
ok thanks alot, i'll try that before anything expensive!
robparker
robparker
Taunton
hi, just to let people know, i went to MB and my friend was working in the parts departement (ususally doesnt work at that outlet) he said i might aswell change the barrel for peace of mind, he just chaged his, and with trade discount the new barrel was £40.
