Ignition issues!
C
clawrence
My problem: intermittent problem on an 06 ML320. Sometimes turn ignition key to second position, the dashboard display "flashes" and goes out, key to position three and dead as a dodo!
Fiddle about and so far have got the car started.
Help!, anyone come across this problem and resolved it? Just replaced the battery but no cure?
C
clawrence
yes, got a brand new key, came with the car!
EdGasket
C180 Esprit 1999
Try giving the dashboard a thump near the key, sounds like a bad connection or dry solder joint somewhere. Could be a relay? Does the car ever cut out once started?
C
clawrence
no cut out so far, will try the "physical" approach, thanks
WG M-B
North west london
C63 Wagon in black
As above a spare key would be useful. Ignition switch is a very common failure.
Around 15 quid from memory
