Ignition Switch 129 Sl320
thewho1971
KINGSTON Surrey
I am pretty sure that my ignition switch needs to be replaced.
Is this a big problem?
Is it an arm and a leg in a garage?
Ray
The switch part is quite easy to do,,I take it that you are not replacing the key section
T
thewho1971
KINGSTON Surrey
Thanks for your reply.
Engine progressively unable to turn over.
Sometimes it will start instantly, on other occasions I have to by pass the switch, taking a positive lead straight to the solenoid on the relay.
Problem becoming more frequent and more difficult to overcome.
(new S/Motor, new gearbox inhibitor switch, not much left is there?!
Ray
You could have a K38 relay this is a starter lock out relay.
This sits on the firewall behind the radio this relay is known to have bad connections causing the starter to not always turn
Tel: 020 8863 9233
