Illuminated Sills Fitted
whitenemesis
CLS55 AMG '05
Another excellent job by Richard and Alfie (comand.co.uk)
Four illuminated sills added with the usual painstaking attention to detail. Pics to follow once the camera has recharged!..
Thanks guys :lol::lol:
Your fuel consumption must be dropping under the weight of all the mods Peter:D:D
whitenemesis
whitenemesis
CLS55 AMG '05
When it drops below 50mpg I'll start worrying Malcolm! :cool::lol::lol:
Well you cannot do many more mods as your signature box only allows so many words;):D
stats007
Hampshire
Looking
Do you think you could spell tyre correctly in your sig, Peter? ;).
I found the illuminated sills on my R129 nothing but trouble :(.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
I have illuminated sills in my clk, LUSHHHHHHHHHHH :) also changed 98% of all the interia lighting to blue led, dash, main switches, steering wheel controls
I think that the inverters fail as the door sills are very long in a SL, I read all of your post on that.
whitenemesis
whitenemesis
CLS55 AMG '05
I think I will have to change the puddle lights to blue LEDs. They look so yellow against the blue sills. Did you need to do anything special to use LEDs?
Miffy
Bromley, London
for the puddle lights I just bought some 38mm festoon blue LED, looks nice when its dark. as for changing the switch LED to blue, please try to get it out of your head, its not an easy task, with most of the led being not accessable for removal, I ended up using a dremel to remove the tops from the led and soldering a 1mm x 2mm (yes thats small lol) blue led onto the now exposed metal.
I am still pondering on doing the comand to blue, but it has 47 led and will project an image in the sky like batmans spotlight if i use the same type of led's lol
whitenemesis
whitenemesis
CLS55 AMG '05
Thanks Mark, I wasn't thinking of doing any switches, just the puddle lights... Oh and possibly the interior courtesy lights.. :)
Miffy
Bromley, London
I didnt do the courtesy lights, the blue ones are just not bright enough, but there are some named FLUX LED that are even brighter so I may do that at some stage, have to see. I did do the boot also, but needs another light on the left hand side as its a bit dim compared to the standard festoon
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
is there any news about these sills available for the R230, either inscribed MB or AMG?
Yes there are kits for the 230,, these work OK as they are not as long as the 129.
Take care of the Ebay versions,they are alli and scratch very easily
pancholi
do you suggest OEM stuff..can you can OEM sills? if not any one reputable?
MB do the retrofit kits for the 230, you could try euromerc he has the OE versions sometimes
