Immobiliser W140 S320
fazzah
Cheshire UK
W140 300SE 1993 + W140 S320 1996
Hi all,
Hope someone can help me.
I recently bought a W140 S320, the electric windows suddenly stopped working and also the radio.
I started the car and left it running while I removed and tested and replaced the fuses in the boot, There was no power going to the fuses.
After stopping the engine and removing the key the car will now not start and the alrm is constantly resetting itself.
I have tried doing what I read from the internet a while ago which is quoted below.
"Unlock car disconnect the battery. for at least 1 hour.. Make sure nothing is on.Reconnect then run throught setup routine lock and unlock the door from the outside with the button on the keyfob, not with the key..do this twice at least with a couple of mins between.sit in drivers seat then wind drivers window down, and exit car, close door,hold keyfob next to door handle press and hold button.. system will lock, then window will go up. then immobiliser will set itself on. if the window does not go up..you have problem.. now put key in ignition.. turn to position 1 single red light.. listen you will hear relays etc stay there for 30 seconds..then to position 2 all dash lights again at least 30 seconds. now turn off remove key.. listen.. 90 seconds now put key in turn pos1 ten sec then 2 ten sec then 3.. and you should be running"
The interior mirror red and green lights kep flashing when I try to synchronise the key using the fob.
At the moment the battery is disconnected and on charge and I will refit it and try again tonight after work.
Any advice would be very much appreciated
Kind regards
Fazzah
Cheshire UK
F
fazzah
Cheshire UK
Hi Television
Thanks for the reply, I tried what you said about pointing fob at receiver etc but still no luck.
I will try again tonight after I finish at work
Kind regards
Fazzah
F
fazzah
Cheshire UK
Hi All
I have tried both methods below but to no avail.
Any further suggestions please.
I might add that it was fuses numbered 5, 6 and 16 that I removed and replaced.
Kind regards
Fazzah
[Point window in remote key at a receiver.
Press the remote button momentarily.
(cars up to 12-93 lock or unlock car with folding key within 30 seconds in door lock)
Cars as of 01-94 with control modules 202 820 40 26 and 202 820 43 26. Switch on ignition with folding key within next 30 seconds.
Cars as of 12-94 with part number 210 820 21 26,
210 820 22 26 also 210 820 27 26 and 210 820 28 26 also 210 820 32 26 point remote key at receiver in interior mirror. press remote button momentarily twice, turn key in ignition lock to position 2 within the next 30 seconds.
What year is the car please and can you describe the key please
F
fazzah
Cheshire UK
W140 Immobiliser problem
I do not know the year exactly as I have not yet got the reistration document and the car has a personalised reg plate on it.
I think it is about 1996
Maybe you can tell the year of the car from the VIN No which is
WDB 1400322A129002
The key is a black rectangular fob with a flip out flat blade and contains 2 off batteries CR2025
there is a number seen inside when the key is flipped out which is:
14076003/0706
Regards
Fazzah
F
fazzah
Cheshire UK
Soryy wrong VIN No given
Sorry the VIN number is:
WDB 140 0322A 28995
SORRY I GOT IT MIXED UP WITH MY EARLIER 140
Kind regards
Fazzah
This is hard without the year.
Try press any button twice turn key in steering lock to position 2 within 30 sec
F
fazzah
Cheshire UK
Just tried that but hazards still flash and wont start
I have been told it was originally N prefix on the reg and that indicates 95/96
Regards
Fazzah
F
fazzah
Cheshire UK
VIN number
I have just checked the VIN number on the bottom of the windscren and it has an extra digit on the end, the correct number is :
WDB 140 0322A 289959
Model S320 95/96
Kind regards
Fazzah
F
fazzah
Cheshire UK
Just received details from previous owner.
S320
first registered in UK on the 03 11 1995.
vin no, wdb 1400322a289959
engine no, 10499422057900.
Kind regards
F
fazzah
Cheshire UK
No power windows
:?:I might just add, before I had the problem with the immobiliser the windows stopped working. am I right in assuming that fuses 5 and 6 in the trunk are for the windows and does it have a relay to supply them or is there a master fuse located elsewhere ?
Regards
Fazzah
I will try and check for you
F
fazzah
Cheshire UK
Wiring circuit
Many thanks for the link Television.
Maybe if I get the windows to work it may help with the immobiliser problem.
Thanks again.
Kind regards
Fazzah
The other thing to do is to disconnect the battery again for 10 mins and try again
F
fazzah
Cheshire UK
  • #17
Many thanks Television.
I will not have time to work on the car until Saturday or Sunday but will let you know how i go on.
I have disconnected the battery for at least an hour each time before I try to reset it.
Many thanks for your help and advice up til now.
Kind regards
Fazzah
F
fazzah
Cheshire UK
  • #18
Nearly there
Hi Television,
Update on my immobiliser problem.
Even though the remote key fob opened the doors and made the lights flash on the interior mirror I decided to fit new batteries to the fob.
And Hey Presto the immobliser problem was no more, yippee.
I still have the problem with no power to the window switches or the window fuses but not had much time to look into that and hopefully will at weekend.
Kind regards
Fazzah
Thats good,,I gave you the diagram for the window,,so that should be easy enough
