Immobilizer using vacuum circuit?
Zanimat
Cambridgeshire
1995 E300D W124
I have a 1988 300D auto and want to improve the security by disabling a part of the vacuum circuit by means of a N/C solenoid valve which is operated by a hidden switch. I was hoping to use the engine stop signal, thinking that it worked the opposite way from how it actually does - now I know better!
Would interrupting the supply to the Vac. control valve on the pump achieve the desired result? Or can anyone here suggest a better alternative? The car is already fitted with an alarm & heavy duty steering wheel immobilizer, but I'd like to make it hard to start even if someone steals the keys.
Thanks in advance,
Malcolm
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
You might be better off using a fuel feed shutoff. Mercedes sell a non-return valve kit for the W124 diesels which includes an electrically-driven valve. I'd suggest using that with a switch. Kit costs a whopping £10.88, part number is B6 6 54 8198
But bear in mind that most cars that are stolen are picked up with a spec lift and towed away. It only takes a few seconds
Nick Froome
www.w124.co.uk
Z
Zanimat
Cambridgeshire
1995 E300D W124
Thanks, Nick; sounds like just the thing! Can you give me any clues about where it's normally fitted?
I doubt anyone would go to the trouble of "lifting" my old lady; hardly worth the effort! And having lost my keys soon after acquiring the car, I know how difficult it can be to defeat the ignition lock! However, I like to try & make it as difficult as possible for the would-be thief.
Malcolm
