Imoboliser
SL 320 1995 auto
I have a sl320 1995. Red light on door handle not flashing. Interior mirror lights working, so does green light on door. However car won't start. Battery good as it's on trickle charger, key fob ok (according to camera test). Could the absence of red light be the cause of my problems. Desperate for help. Thanks.
Sent from my Nexus 5X using Tapatalk
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
I replied to your post yesterday. Have you tried to re-sync the key to the alarm/immobiliser as I suggested ?
E
SL 320 1995 auto
Sorry, but haven't received your previous post. Could you please resend info on resyncing. Many thanks.
grahamcol
West Midlands
Sit inside car doors unlocked and with key in your hand. Aim remote at mirror and Press button twice. Turn ignition lock to position 2 within 30 seconds. Good luck.
E
SL 320 1995 auto
Done that, no luck, doors lock and open, but nothing else. Thanks anyway. Any other advice willingly taken onboard.
grahamcol
West Midlands
Others have suggested removing the immobiliser if it's a dealer fitted one and this would seem to be a good idea if nothing else works. Sorry but I cannot think of anything else.
E
SL 320 1995 auto
Ok. Many thanks for your time. I'll post how/when it's fixed for others.
Uncle Benz
West Sussex
Mainly Mercedes
You will need at least one red and one green working or the immobiliser won't disarm. Not too big a deal to wire one led in if required
E
SL 320 1995 auto
Hi, I'm intrigued by that, my sl320 only as one red and one green on the door handle, and same again on interior. The red on the door as stopped, but the interior two still work. You say at least two are required to disarm immobilizer, but I have three working ( one green on door and two red/green on interior mirror) but my immobilizer won't disarm! Grateful for any help at all as I'm not very technically minded.
Many thanks
E
SL 320 1995 auto
Good evening. Update on my sl320 imoboliser problem. Finally found some space in garage now better weather as arrived. Remembering all advice previously given, I thought I would have a go. On my '95 model I have a small lift up "accessory" compartment top centre of the dash at the side of which is a key hole which locks and unlocks this compartment, which is strange because when locking with remote, all compartments lock anyway. However, I tried the "skeleton" and it operates the imoboliser. Don't know why or what went wrong initially, but at this moment I'm back up and running. Thank you all for your input.
E
SL 320 1995 auto
Ps. Still got no red door light flashing indicator. Can't have it all.
