Impact wrench choice for car work...size vs torque
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Conor, Feb 14, 2020.
  1. Conor
    Conor Senior Member
    1,096
    414
    Jan 22, 2019
    London, UK
    Your Mercedes:
    So...
    I have wanted one of these for a while but could never justify it (or need it, for that matter). Now that I am working on my alternator, I need something to release the nut holding the pulley - and it will be useful for track day wheel switching.
    A few months back I bought a DeWALT cordless drill with 2 x 4Ah batteries, so it's a no brainer to get a similar branded wrench..
    I have found these two for the same money at £159.99. One is more compact at the expense of lower torque than the other with higher torque, in a bulkier unit. Wondering what is best for a car. I am inclined to think that the compact, "weaker" unit should suffice as it may reach places the larger one can't. Considering a lot of applications for torque wrenches revolve around construction etc. Cars, in comparison are lighter duty??
    1. DEWALT DCF899N-XJ 18V XR BRUSHLESS - Max torque 950Nm
    2. DEWALT DCF894N 18V XR BRUSHLESS - Compact - Max torque 447Nm
    Is the 813 Nm breakaway torque of the compact unit enough for a car? I guess it is??
    Any opinions?
    Conor
  2. Tony Dyson
    Tony Dyson Senior Member
    1,453
    605
    Aug 26, 2018
    God's Country
    Your Mercedes:
    2014 C 220 CDI W204 OM 651
    I can't find any details of what the tools are rated to torque from? I think you would have more use for it at the lower end?
  3. AnthonyUK
    AnthonyUK Senior Member
    518
    274
    Apr 17, 2018
    Alton, Hants
    Your Mercedes:
    C240 estate 2002
    The 899 I saw on the Mercedes source youtube channel where it was used to remove a crank pulley bolt, the only battery powered one that could do so. It is however very bulky and may limit where you can use it.
    I have just bought a Ryobi model rated at 420nm which is adequate.
    It does require a high output battery to work optimally e.g 4-5aH.
  4. Rob76
    Rob76 Senior Member
    196
    109
    May 13, 2018
    Coventry, UK
    Your Mercedes:
    S211 E280 CDI Sport
    Wighty likes this.
  5. Oldspanners
    Oldspanners Senior Member
    761
    561
    Oct 30, 2017
    Normandy
    Your Mercedes:
    C CLASS 2004 C180
    Ordinary hand tools will take off any normal fasteners so I'd go for the largest torque rating, the one mentioned on Mercedes source seems to have the highest torque at the moment to such an extent that he is now going to change over from pneumatic tools to electric.
    As with all power tools access to restricted space is always a problem.
  6. ianplymouth
    ianplymouth Senior Member
    312
    39
    Dec 24, 2013
    Plymouth, Devon
    Your Mercedes:
    SL55 amg, Renault G Espase 2.0Dci 175+, Megane 265 cup
  7. mercmancdi
    mercmancdi Senior Member
    3,244
    685
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    I would always buy the smallest I can with the highest tourqe ,
    I thought I was great couple of yrs ago bought big powerful gun with no adjustment. Ended up it would fit very few places only wheels etc and even then had to be careful not to snap them. I then bought a smaller one less power but at least it fitted in behind the wheel to take off callipers etc and I bought a breaker bar for anything too tight for the gun, and then used the gun once the nut / stud etc moved slightly. Big is very limited as to where you can use it.
  8. OP
    Conor
    Conor Senior Member
    1,096
    414
    Jan 22, 2019
    London, UK
    Your Mercedes:
    I think that is solid advice... I wanted this gun to be last word on breaking open stuff. But I guess it's no use if I can't use it anywhere.
    I am going to go go and have a look at both of them now and see. The smaller one with 425 should still be ok for most bits I would imagine.
    By the way.. the mammoth 900Nm unit has 3 settings.. It works for both opening and also tightening. Ken on Mercedes Source put it on low setting for wheel nuts and it would click/stop below the desired torque for the nuts, which he was mega impressed with. Just saying it's not only a brute force machine and the smaller will probably function the same.
    mercmancdi likes this.
  9. LostKiwi
    LostKiwi Senior Member
    21,428
    10,881
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    I have the same Ryobi. Quite impressed with it to be honest.
    Conor likes this.
  10. bembo449
    bembo449 Senior Member
    4,154
    1,285
    Jan 2, 2012
    gainsborough , lincolnshire
    Your Mercedes:
    w221 320cdi , r170 230k , land rover discovery 3 , insignia vxr , shitron dispatch
    I have an 18v snap on at the mo but when it dies im goin with the dewalt XR with the most go in it
  11. umblecumbuz
    umblecumbuz Senior Member
    4,035
    1,409
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    Agree with this philosophy. I've watched Mercedes Source for years and have a lot of confidence in Ken's advice. An impact gun with high torque and adjustability would be my ideal. I bought a cheapie years ago (air driven) which just about fills my needs, but I would like a better one now they're getting more powerful and versatile.
    I have Hitachi electric everything else, so it would have to be a Hitachi.
    Conor likes this.
  12. mercmancdi
    3,244
    685
    Dec 6, 2011
    Your Mercedes:
    Actually this is what I bought.
    DEWALT DCF894N 18V LI-ION XR BRUSHLESS CORDLESS IMPACT WRENCH - BARE (442HP)
    Conor and bembo449 like this.
  13. OP
    Conor
    Conor Senior Member
    1,096
    414
    Jan 22, 2019
    London, UK
    Your Mercedes:
    Yes, he seems like a very grounded and reliable source.
    Me too.. I have ordered that and will collect tomorrow :D - I think 447 Nm will be enough.. and it even has higher breakaway torque, which I assume to be a torque that is applied as a "boost/impact" when it detects a stuck nut.
    It will be smaller and should do the job.. I like the idea of the bigger one being "the last word" in handheld torque.. but I do think it will be overkill for my needs.
    Yea, Ryobi are good too, my dad have some stuff from them at home and it's decent. I just got the DeWALT drill on special offer with 2 x 4.0 Ah batteries a few months ago for £150, which I jumped at.. So it makes sense to keep in the family.
    I did get the Milwaukee cordless wrench though, but that seems unique and I hadn't seen similar from another brand. I won't continue with Milwaukee as I think it's a bit pricey/overkill for amateur, infrequent use.
  14. Chrishazle
    Chrishazle Senior Member
    2,990
    740
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    If you want to look at a load of different manufacturers tools and fancy a trip to the Kent Showground, Detling, near Maidstone, the FFX Tool Show is on in 2 weeks time, free entry/parking, loads of tool suppliers every year including DeWaly, Metabo, Hitachi etc etc etc.
    https://www.ffx.co.uk/tools/toolshow https://www.ffx.co.uk/tools/toolshowexhibitors
    Easy to get to - M20 J7, A249 towards Sittingbourne, get in LH lane as you go up Detling Hill and follow the queue/marshalls signs. Prices at the show are normally very good, I'd recommend going the Friday as I suspect the weekend days will be very crowded (we've been twice, both times Friday and it was OK).
  15. Frontstep
    Frontstep Senior Member
    7,046
    921
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    I bought a Milwaukee jigsaw recently and was impressed, never had their stuff before it is chunky stuff though.
    Saying that I bought a Bosch Pro laser and that's very good a bright green self levelling thing.
    On the other hand I keep saying I will do less but keep buying stuff ?
    I have a biggish extension job I will avoid contact with, well I will try and convince myself I will anyway.
    Perhaps I need a hobby ?
    Conor likes this.
  16. OP
    Conor
    Conor Senior Member
    1,096
    414
    Jan 22, 2019
    London, UK
    Your Mercedes:
    That's a very interesting idea.. I might try and make it down there on the Friday. Thank you :)
  17. Chrishazle
    2,990
    740
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    Beware the speed cameras both sides of the road at the bottom of Detling Hill. Depending on what part of London you're coming from, may be better to access via M2 except you can't turn right across the dual carriageway to get into the showground so have to go a long way to do a U turn! Same when you leave, you have to turn left towards the M2 and go a long way to turn if you want the M20!
    Conor likes this.
Share This Page
