indicator/hazard/washwipe problem
hugh55
hi can anyone help i have an intermittent problem the indicaors ,hazards and the wipe of the wash wipe stop working for a while then start working again all the oher electrics seem ok fuses ok any ideas would be a great help thanks: e220 1995 estate
The stalk by the steering wheel causes most of these problems,,cleaning it with a good switch cleaner often solves it
kth286
E320 Coupe 95
Did you try TURNING the appropriate fuse in it's holder to make better contact.
That normally works until you get new fuses and clean the holder contacts.
Next time it does not work just turn the fuse several times in the holder.
If that does not work, could also be the relay.
Always worth doing what Kth286 says get a non drying switch cleaner from Maplins doing the rotating as said above
H
hugh55
thanks
thank you for your help i will try and let you know how i get on cheers hugh
H
hugh55
ok now
thanks again cleaned fuses and relay pins as suggested once again advice spot on problem solved big thanks hugh
