Indicators again - 129 - 300sl - 92'
northcave
300sl/1992/3l
Ok so i;ve been through this a while now. Indicators stopped for like weeks and thought a component in the relay had blown. However it has started again and within a 10 minute drive they'll start and stop working about 5 times.
There is obviously a didgy connection somewhere.
Does anyone know what this sounds like?
Television - sound like something you can fix?
I saw one the other day where the pins join on the circuit board where all dry jointed, it could be the socket connections that need tightening a little.
I will check your one over for you if you wish.
N
northcave
300sl/1992/3l
Television..
On my 129 820 10 26 relay for the indicators... do you know which pin is the earth? Not sure why but i have sneaking suspiscion that it might be a bad earth.
Its got 6 pins in one set and then 21 in another.
I'll try that and failing that i'll put it in the post today.
cheers
Tim
