Induction system blown off to pieces.
giki
Hi everyone,
I just bought a E320 with the M104 straight six and the problem is that there is an intake from the air filter to the mass sensor which has blown to bits(3 pieces to be precise). It singed the rubber connecting it to the filter. I started the car normally and heard a small "bump" and the car was idling normally. As i drove 20 meters it stopped and said battery charge on the display.I put in a new battery and when i opened the bonnet i saw the pipe was blown off. What could be the reason. A backfire possibly. Otherwise the car has been great till now.
kth286
E320 Coupe 95
If it has "battery charge" on a display it will be the 210 model.
Although same engine layout in essence.
Is the front drive belt still intact ????????????
G
giki
Hi, i am not running on LPG. People tell me it happens a lot in LPG cars and that bit blowing off. Car is at mechanic and he tells me he doesnt know what it is.
Service is due in 4000 kms.
Front drive belt is still intact.
G
giki
Hi guys, my mech found out it needed a new air mass sensor which has been ordered but there is a rubber pipe and a plastic pipe that travel to the intake manifold. It had the AMS number on it and i dont know what they are. Any help would be greatly appreciated.
G
giki
Hi, heres the items marked in green that i need. The yellow is the AMS as you all know. Thanks.giki.
G
giki
Anyone to help: :sad::sad:
G
giki
Thanks for the reply Nick, but i dont know what they are called so what do i tell him when i ring him. I can only mention that it is a rubber hose and a palstic hose.:p:p
Mind helping me out with those. I did ring them and they said that its 200 for the full kit.
Cheers and BTW which Merc do you own cause i live In Nth Melb and might c if u can help me out with it.
