johnhogg441@
- Mar 19, 2021
- G Wagen 460 280GLE 1985 - Petrol (110) - 5 door
Hi - I hope someone can help - I have a problem with my 2006 Viano Diesel injector wiring. I recently had the No1 injector replaced as it was not firing. The mech noticed their was damage to the wiring near the injector and improved the connection at the soldered joint. I have had the same misfiring problem re-occur and have replaced the plug to No1 injector. The problem still is their - not firing on No1 injector and the fault shows as No1 injector with open circuit.
I presume there is another break somewhere in the loom but cannot find anything and all the other injectors are fine. I notice on ebay that there are some injector plugs for sale with long leads pre-soldered onto the plugs - is it possible to re-route the wiring for the injector direct to where ever the lead goes to?? If so, where does the wiring for the injector go to??
Any help would be appreciated as the Viano is now in the garage and I fear the only solution would be a replaced injector loom - and that might/will be very costly.
Cheers John
Cheers John
