Is it possible to remove the instrument cluster on a 300D without the special tools that are shown in the manual... can these tools be fabricated easily??Thanks, R. Barrett
You can make the hooks from wire clothes hanger or buy them on Ebay, on some if there is room you can push them out from the rear, with hooks make sure that you are behind the cluster and not the glass.
Thanks... I am not there just yet... still struggling with the steering wheel. I have had it off before but it was a long time ago... Thanks again!! R.Barrett
There... I got the cluster out... thanks... Next question... Does the air bag on the passenger side have to come out before the dashboard can be removed...? It is not addressed in the manual that I can find. If it had a glove compartment, it would be simpler. There are some fasteners behind the glove compartment and I was figuring that the fasteners would be behind the air bag...?? I am sure that the bottom of the dashboard on the passenger side must be removed. R.Barrett
Yes... The evaporator... it is a long way down in there. I am at the point right now of trying to figure out how to "turn" the ignition lock. I cannot find the pin that the manual tells you to press in order to turn the lock so the cross member can be removed. I will get it... a matter of time... Still, if there is an easier way to remove the evaporator, I like some advice (other than taking it to a shop... I can mess it up myself!)lol... R.Barrett
Yes.. a 124 300D. Just as I posted that last thread, I went back out there and gave it another look and found the pin, turned the lock and removed the crossmember... I swear I looked at that thing for forty minutes and didn't see it... I guess the next thing is to start skinnin' out the box to get to the evap... I am wondering, though...does the whole plastic box come out with the evap and heater core together or can the evap be taken out without removing the whole big black box containing both the heater and the evap...??R.Barrett
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
