Instrument Cluster change w203
memet
London
C-Class 200K Coupe Evolution
Hi
I would like to change the instrument cluster as my original one is fading on the lcd display. If I replace it with the same one will it show my original miles or do I need to get it re-programmed ?
Mem
You can get it repaired for £100 and nothing to program
memet
London
Thanks very much for that :) I was about to buy a brand new one. Would you happen to know where I could get this done I live near croydon
www.actronics.co.uk 01206 849920 they are in Colchester
Sorry its £127 now but you get a new display.
If only the display do look on Ebay as there should be kits to fix this your self for £20
Dont buy a 2nd unit, they cant be re-coded as a rule, Mark might be able to but your standard star wont......
Miffy
Bromley, London
CLK 320 CAB Elegance C208
buy a repair kit from ebay for £20 and spend an hour of your time fixing it.
Pathfinder
Gourock
I need one of these repair kits, tried a search, only can find repair service at £100. Would you have a link to a good kit?
duncanh
Wiltshire
BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
Any links to a repair kit for a W203? Mine is also starting to look a bit faded.
memet
London
Thanks Guys you've all have been a great help!! Being an ex panel beater/Sprayer should be easy for me to change
Cheers
Mem
Alps
london\Essex
2019 E63s S213, SOLD - 2013 Weistec E63 AMG, SOLD - 2004 E55 (x2)
used ones need the milage resetting\virginising\zero`d then you can use star to program it to the car like a new one
memet
London
:confused: Hi
I fitted my new lcd thanks for your help I now have a malfunction saying
"SRS Restriant system visit workshop" for some reason my rev counter looks to low and not sitting on the 0 when engine is switched off please advice on wheat can I do
Regards
Mem:confused:
The SRS may just need to be cleared on STAR if the ignition was turn on with anything removed
You must have disturbed the rev counter and all you can do is to take it out again to see
memet
London
Rev counter
I know what I did now! At first I thought I had to remove the needles I slightly tweaked the rev needle then realised nope this isn’t the way then I worked it out fitted the lcd that's when I noticed it after re-resemble and starting up the engine.
Can that needle be removed and re-seated in the idle position ?
I've caused more work for my self
Cheers
Mem
The needle will lift off. Noe the end stop is at about 7oclock so re fit the needle at 6 and then just lift the end of the needle over the end stop then it will have a little tension and read better:D
memet
London
Rev Counter
Hi T
Brilliant mate all done and showing the revs correctly thanks for all your help much appreciated , just need to get the system reset now.
Regards
Mem
Pathfinder
Gourock
STAR seems to be the suggested solution for most problems. But when posters suggest STAR, they seem to forget that it costs a lot of money to run a STAR check. I know mechanics who can diagnose many faults without it. Maybe because they are top notch?
I have always managed to fix my 203 without paying for a STAR diagonstics, and it's almost 14 yrs old. Touch wood,
memet
London
  • #20
Rev Counter with SRS malfungtion
Hi Pathfinder and Televsion.
With all your previous answers on how to fix my LCD on fading thanks again.
Thinking I had to remove the rev counter first to change LCD I tweaked the rev counter very slightly it made a noise like “little plastic ring gear grinding together" that's when I stopped.
I removed the needle and re-positioned which has worked as per instructions from Television. In your opinion might have damaged the rev counter and made it faulty? Or getting the system reset will fix my the issue
As you guys know I am new to all these morden cars what does STAR mean
Regards
Mem
