instrument cluster mileage unlit
b.schmidt
a class 170 CDI the instrument cluster works fine but the central window which shows the mileage , clock temp etc is unlit.
I can hardly see the information and was wondering if this is lit by a bulb or if the readout is broken and the cluster needs replacing / mending ?
drdre78
london
mercedes c200 200
hi yeah bulb has gone.you can replace bulb.just need to remove cluster
Hertfordshire Merx
A160
Yep there is a bulb behind the screen. Lower your steering column and remove the cluster. only tool needed it a posidrive screwdriver.
B
b.schmidt
any idea what type and volt the bulb is ?
Thanks for the advice . I was about to get a new cluster
There is a huge difference in the cost of a new bulb circa £1 to a new cluster at £1k
A
andy@pcd-ltd
There are four different types of bulb in the cluster ranging from 1.2watt to 1.5watt and also green or colourless a chassis number might help but the only other way would be to take it out and go to the dealer for them to match it up
