intermitant charge
Status
Not open for further replies.
turbo18zx
another problem 200 series mid 90s
diesel
new battery and alternater
will intermitantly flatten battery then after jumpstart run for a couple of weeks then flatten battery again
any ideas :?:
(get one running for a friend they come out of the wood work )
thekeeper24
New York
hey,
im not too familar with the mid 90s MB, but on the older diesels the causes of something like this were most likely:
-a bad connection of the wire leads most likely at the battery posts or just bad cables.
-the glow plug relay maybe coming on intermittenly and draining your battery.
-battery
-alternator
- or you have a really pain-in-the-ass electrical short somewhere :cry:
-just some common areas to look into, but im sorry im not familar with your model.
-best of luck :lol:
-mike
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
just a thought, could it be an intermittant faulty interior boot light draining the battery down over night? Have a look at boot switch, if nackered take out bulb for temporary fix.
Regards Mike
T
turbo18zx
thank you will take a look at these
as its a friends car dont rearly know precice details as to when it happens ie does he go into the boot before it goes flat
thans again
will post back soon
T
turbo18zx
turned out to be the heater plugs relay
dead easy had melted bottom of plastic case
the intermitent draining was caused by one of the terminals floating (due to the damaged case) and earthing
Status
