Intermittent Electrical Problem - 1998 C280
74merc
Northern Ireland
C280 Sport Estate
Hi, whilst driving to work this morning I temporarily lost all power to the indicators, wipers, electric windows and sunroof. I've done some searching and it seems to point to a relay problem rather than a fuse problem. I believe the relay in question is an N10, does anyone know if it supplies power to all of the above.
Cheers
Martin
Dec
Ireland.
W202
This is just for reference as your car is much later but the N10 is in around number 1 in picture others will enlighten you some more. I think the windows/sunroof aren’t on the N10 but there may be a relay in boot but not sure about that.
Dec
attachment.php
As Decs post or the ignition switch going faulty
74merc
Northern Ireland
C280 Sport Estate
Thanks Dec and TV. I must see if I can find a wiring diagram for this. I know this will fail again, hopefully not when the windows and sunroof are open!
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
When and if they fail again, turn the ignition off, remove the key and open the drivers door as i believe you should have a courtesy system which puts power on the windows and the sunroof, it goes through another control unit (comfort control i believe) my understanding of the system is this comfort control unit takes over the window and sunroof functions thus eliminating the N10 relay, if they still don,t work i would be suspecting the unit in the fuse box, which MB call a SAM (Signal Acquisition Module) its the unit that the N10 relay plugs into.
Please bear in mind this is how i believe the system operates, and it is where i would start from if it was my car.
