1BrokenMerc
- Aug 4, 2024
- C250D AMG Premium Line - 2016 - 2.1l Diesel
My car is 8 years old with about 24000 on the clock regularly serviced by non MB garages. Having just travelled about 250 miles then did a short trip of about 2 miles shortly after. I was attempting to spin my car around at a wide junction, on full lock applied, when the steering failed and up came the "Power steering malfunction - See owner's manual" on the dash. I struggled to drive back the 2 miles with extraordinary heavy steering. The following day I was looking for the cause when I discovered the warning message had disappeared and the steering was functioning as expected. A short drive later with nothing like full lock applied I'm in trouble again. I shut down the car - turned off lights etc and the power steering functioned again.
Couldn't get a dealer to look at the problem for 3 to 4 weeks and I needed to do the return journey within the week - oh b----r!
I now have the vehicle home and want to exploring if the issue might be something straightforward to fix.
Certain it is unlikely to be:
+ related to the vehicle battery;
+ a fuse problem;
+ a grounding problem;
+ a software issue.
I think it may be a steering rack fault since wiggling the steering wheel results a light clunking noises - like worn teeth on a pinion are riding over mating parts.
I see 'used' steering racks online so was wondering:
can the steering rack be easily removed and replaced without the need to reprogramme anything?
am I likely to be able to acquire and replace parts in the steering assembly?
am I looking at the issue fro the wrong angle?
Any pointers/suggestions please folks?
+ a fuse problem;
+ a software issue.
