ipod using cd changer connections.
hawkeye
w211/07/280 CDI
I'm almost embarrassed to ask this - given the number of ipod questions I just found when I searched.... but I can't find an answer to this specific question.
I've got an audio 20 with cd changer connections - but the previous owner took out the changer.
Does anyone know of an ipod connection that will connect straight to the, now free, connectors?
All I can find are connectors that (as far as I can tell) require me to rip out the console to get to the back of the radio :-(
many thanks,
john.
psmart
many thanks,
john.
Dension Gateway 500, a bit pricey, but connects into the D2B Fibre Optic loop of the CD-Changer and allows you to use an Ipod and a Hard Disk/USB stick which is treated like a CD-Changer. Very quick to install and so far mostly fault free (had to reboot by fuse removal a couple of times as it became locked up). As long as you have power connections you could install it where the CD-Changer used to be.
Alfie
Surrey/Cotswolds
www.comand.co.uk
many thanks,
john.
If you have an Audio20 and your car is an A/B/C/CLK/ML/GL or R class then the factory ipod kit will work in your car. If your car is an E/CLS then it wont unless you have Comand.
If you do have an E/CLS with the fibre, power and wakeup cables with audio20 then Dension might do a product for you. Your car will be MOST based not D2B if you have audio20.
I find it odd that someone left the cables there because this would break the MOST ring and render anything else on the ring, useless.
avsdoyle
Belfast, Ireland
W209/2004/320 Petrol
I had good experience with a Dension Gateway 500 in my 2004 CLK. It is a D2B based system to the Merc solution for IPOD was not an option. I can control the songs and play lists via the steering wheel controls but I don't get any artist or song info displayed. Just a track number and CD. Once you learn the Denision user interface it is easy enough to use.
If you have a MOST bus I would go for the Mercedes solution. It should display more artist/song information on the dash from the ipod and even be a little cheaper.
H
hawkeye
w211/07/280 CDI
MOST Ring break?
Ring broken?
Well, It hasn't - Audio20 still works OK - but I don't know what else is on the ring?
I can see the pretty red light flashing in the cable so definitely still connected.
cheers,
John.
Alfie
Surrey/Cotswolds
www.comand.co.uk
Ring broken?
cheers,
John.
If you can see red flashing light then the ring is broken as with it connected, you cant see a thing as the ends are not in view.
For the head unit to see a Cd changer then the AGW in the head unit needs to be programmed to recognise a CD changer on the MOST bus. We have enabled a few cars for customers who have Dension systems but just need the car to be told there is a CD changer present.
Your car is an 05 C class I presume from your signature. So it is MOST based.
fitting a genuine ipod kit is very straight forward and will give you the most functionality/flexibility.
H
hawkeye
w211/07/280 CDI
Is Phone on MOST ring?
Thanks for that Alfie,
I've just got a phone cradle and it doesn't work - is the phone on the MOST ring too and thus it's not working due to CD changed connection dangling?
()I asked this in a different way on a diff question so apologies)
many thanks again,
John.
