W210 E320 cdi estate - when I put the key into the ignition, it clicks as per normal but then WILL NOT turn. Absolutely wierd as yesterday it was fine.
I've just had the Crank position sensor replaced (at great cost because it wouldn't come out so they had to remove greabox ), and they said that the battery had gone dead (why I don't know), but the key has worked since then.
I thought maybe the battery was low even though it's only 6 months old, but jump starting didn't help. The car locks/unlocks fine via the remote function on key.
The only thing I can see is a light covering of dirt in the ignition 'hole' sensor, but it's always been there.
Any ideas?..please help, thanks.
