irratic throttle
Septic
Hi folks
Need some help with my 99 w202 c180 when i start the car the rev's fly up to
3k and the fall tp below 5 and then it cuts out when driving it the throttle occationaly becomes very sensitive and excellerate's alot harder than usual.
any idea's
Stephen
nickcc101
Helston Cornwall
Presume that you have the 111 2 litre engine. I had similar problem that turned out to be the throttle butterfly sticking in the housing due to oil contamination, removed throttle housing and cleaned sticky contamination off. Now been ok for last few months. Housing at the end of air intake held on by allen screws.
There was a post 1 or 2 days back where the problem was a micro switch on the cables assembly
Septic
Hi guys
Ive cleaned out the throttle body it was very contaminated mind you it has done 163k. The symptons have now change now it hunts ill have a go at the micro switch next.
Thanks Stephen
Hunting is an air leak on the intake, thats 99% sure. check all plastic pipes
Septic
Mission accomplished The thick black pipe that connects to the top of the inlet manifold wasn't quite connected to the black rubber. runs sweet again.
thanks
Stephen
Septic
still doing it
Still playing sily buggers so i disconnected the block connector comming from the throttle housing its now running fine so i think i may need one of those micro switch's.
Stephen
