- Dec 8, 2009
- Location
- Bristol/Somerset
- Website
- www.avantgarde-automotive.co.uk
- E300 Coupe AMG Line PP/NE, SLR McLaren Roadster, SL55 & C32AMG
C200 petrols only have 1 NOx sensor.
If you are under warranty get the dealer to do it.Thank you Steve
I'm new to all this the Car was for my retirement and have been disappointed now I will confront Mercedes you have given me hope really appreciate it can i also ask you my auxiliary battery malfunction message comes up on the dash board do you think i should get it fixed from mercades or an independent garages as i have lost comfidence any idea of cost also i live in the midlands
Very similar situation to myself.Good morning all
I purchased a c200 petrol Mercedes-Benz from Cambridge in 2018 registered in 2015 used car. It is under a service plan for 4 years my issue is I have had both NOX sensors replaced in a period of 2 years 1st 2019 and the second in 2020 now one has failed showing
Bank1 Sensor 1 I only drive 5000 a year the car is well maintained Mercedes have said as I had a extended warranty they will not give any thing towards it they also want £120 to check which one is faulty
Can anyone help with advise.
The part itself should have one years warrenty if it a mercedes genuine part (in case it was the last one you had replaced)Good morning all
Mercedes parts have a 24 month warranty, although as had been said earlier payment has to have been made for the warranty to be initiated. If the parts were replaced for free then there is no new or additional warranty from the original part.The part itself should have one years warrenty if it a mercedes genuine part (in case it was the last one you had replaced)
I paid £400 for the warranty originally plus Mercedes-Benz parts have 2 year warranty?I believe you can’t get warranty on replacement warranty parts unless you make some sort of payment to said replacement part.
I'm following in your footsteps buddy.Hello guys
Thank you for your fantastic support,
I have been in contact with Mercedes they say because your NOX sensors were replaced under the used car warranty from Mercedes they can not cover them as the policy must be in force .I have told the dealer that is irrelevant as all parts come with 2 years warranty and I have a petrol engine with 51000 miles so the parts were not fit for purpose the problem still exists after 2 sensors they said they will get back to me due to the parts not being available because of the chip shortage they said we think they should be covered but be mindful you may have to pay. I also stated I did 9000 miles in 2 years they should last for at least 5 years waiting for a response.
Could you guys also tell me how much it costs for a auxiliary battery fitted my is flashing on and off saying auxiliary battery malfunction..
Exactly.May I ask based on the - no warranty on parts if no payment made............................ if original part "not fit for purpose" and replaced by a batch of those same design original parts "not fit for purpose" rather than the newer redesigned parts................and subsequent failure occurs, then consumer expected to pay for rectification?
We know of repeated NOx failures on many same vehicle(s) - just seems a little unfair to the consumer.
My VIN is WDD-2050422.....Picture of exhaust for C200 here detailing parts:
Mercedes-Benz Teilekatalog (Ersatzteile online)
mb-teilekatalog.info
To be sure this is your model can you please post the first six numbers of your VIN (205xxx - need the X's to be certain).
This is a 205042. Clearly shows one exhaust and one NOx sensor (item 250) part number A0009053503
Ok so that was the correct part number and there's definitely only one.My VIN is WDD-2050422.....
