Is this a gearbox issue?
MercM2Mb
W211 e220cdi 2008 w213 e220d 2019
Recall conserning Sprinter passenger and commercial vans 2017_2022
A12/01863/22
A component of the parking lock system may wear out. As a result, the vehicle may begin to move out of parking position, increasing the risk of an accident.
The product does not comply with the Regulation on the approval and market surveillance of motor vehicles and their trailers, and of systems, components and separate technical units intended for such vehicles.
Botus
S500/2010/500
pretty sure the law is for a parking brake.... the term parking lock, I think would infer the pawl in the auto box, but then it doesn't need to work as its not the bit at the start of the sentence
any red text below is an addition by me, the rest is the UK construction and use regs - bold just for emphasis
https://www.legislation.gov.uk/uksi/1986/1078/schedule/3/made
The parking brake shall be so designed and constructed that—
(a)
in the case of a wheeled heavy motor car or motor car, its means of operation is independent of the means of operation of any split braking system with which the vehicle is fitted;
(b)
in the case of a motor vehicle other than a motor cycle or an invalid carriage, either—
(i)
it is capable of being applied by direct mechanical action without the intervention of any hydraulic, electric or pneumatic device; or
(ii) WOW so NO electronic parking brake is actually legal in the UK ?
the vehicle complies with requirement 15; and
(c)
it can at all times when the vehicle is not being driven or is left unattended be set so as—
(i)
in the case of a track-laying vehicle, to lock the tracks; and
(ii)
in the case of a wheeled vehicle, to prevent the rotation of at least one wheel in the case of a three wheeled vehicle and at least two wheels in the case of a vehicle with more than three wheels.
17 The parking brake shall be capable of being set so as effectively to prevent two at least of the wheels from revolving when the trailer is not being drawn.
18
(a) in the case of a motor vehicle, its means of operation (whether multi-pull or not) is independent of the means of operation of any braking system required by regulation 18 to have a total braking efficiency of not less than 50%; and
(b) in the case of a trailer, its brakes can be applied and released by a person standing on the ground by a means of operation fitted to the trailer; and
(c) in either case, its braking force (there is NO braking force in an automatic gearbox's parking pawl - all it effectively does is stick screw driver in the gears when stationary to jam it up), when the vehicle is not being driven or is left unattended (and in the case of a trailer, whether the braking force is applied by the driver using the service brakes of the drawing vehicle or by a person standing on the ground in the manner indicated in sub-paragraph (b)) can at all times be maintained in operation by direct mechanical action without the intervention of any hydraulic, electric or pneumatic device and, when so maintained, can hold the vehicle stationary on a gradient of at least 16% without the assistance of stored energy.
mioba
Nottingham and Köln
Its an elextric switch that activates a mechanical brakep
Botus
S500/2010/500
Its an electric switch that activates a mechanical brake
is capable of being applied without the intervention of any hydraulic, electric or pneumatic device
mioba
Nottingham and Köln
Hmmm clearly is odd then as most cars now would then fail - sure there is a workaround abvioualy
davidsl500
The stipulation is the force must be maintained mechanically without intervention of electrics etc., when the vehicle is not in use i.e, after the brake has been applied. It doesn't state how the brake can be applied...
Botus
S500/2010/500
it does say with out electrics... its was all there in bold to make it easy to read two days ago
Botus
S500/2010/500
oh dear and another regulation making the auto box park unsuitable
as a diff is open (as it is on all cars - as even a LSD isn't locked up to 30% unless power is applied) ..it actually can't hold ANY wheels still - if enough grip on the axel PARK is in operation upon it "should stop the vehicle moving" but either wheel is fully capable of being turned any amount at any point
V6Matty
Newark, Nottinghamshire
Electric parking brakes are still mechanical and can be activated and deactivated manually,
