It's broken
andy talbot
bratfud
W204 2012 2.1 estate
Replacing fuel line ...nightmare infuriating awkward T₩@t of a job 1524483104427-1471927914.jpg
Taffy7hfa
Oxford
Your new return pipe from the back end of the rail should be underneath the injector pipes. 270cdi.jpg
andy talbot
andy talbot
bratfud
1524495292309726338270.jpg It was harder to remove than fit new one ,took all injector pipes off and the high pressure pipe off the rail the old one had been rubbed through on the ancillary belt .
When I fitted new one it was in same position as old one slackened off clamp and twisted push fitting round and tightened it up ........all done
andy talbot
andy talbot
bratfud
That's why it was a pig to get return pipe off it was under the injector pipes I was just being lazy
om613
london
S202 C250TD, S123 240TD
Did you replace the two clips that stop the pipe touching the belt?
andy talbot
andy talbot
bratfud
Ha ..what clips .....none there just twisted pipe and and tightened clamp ,it is well out of way now
www.ckinsurance.co.uk
