Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
So guys,
It's been a while.. i've been totally snowed under with two other things. Work and working on my unmerc which has consumed all my weekends working physically.. and all my spare time learning about wiring looms and body work - prep, spray and most recently welding due a big hole I found.
Over the past 12 months I have been keeping an eye on my E350 that now has about 204k miles.
It's sick. The valve stem seals are shot on at least two cylinders. They definitely need doing. I'm also convinced the intake valves are totally caked up with carbon. I'm sure the carbon is the cause but the engine seems to knock a lot... Also, some days the car seems to drive totally sweet around town with instantaneous poke and no hesitation, other days not so much. I feel like i've probably not experience the full refinement of this engine yet.
I've tossed up the idea of just keeping the oil topped up (1.5 litres per 700 miles) and just driving into the ground.. What will ultimately happen is the cats will get destroyed and it will fail emissions.
But then it dawned on me.. if that happens I'll have to go back to the market to buy the same car again (I love that car). That will cost me at least £8/9k if I can find an S212 Petrol 350.
I also plan on keeping this car until the government tell me I need an EV. I simply love the car. Power, practicality and comfort. There is nothing to change to for my daily and any change will cost me.
So... the most outrageous one sounds like the most feasibly approach. Engine rebuild.
I'm currently renting a unit in my home town and when the Clio is done, I am going to take out the engine, strip down the ancillaries and send it to an engineering firm to be rebuilt. Definitely the two heads. Jury is out on bottom end rebuild but I feel if I am going this far I may as well.
I anticipate that by me doing the grunt work, it should reduce the cost (a bit).. And while the car is in this state I can tidy up a few other bits such as bushes, suspension body work (possibly new paint). Wheel refurb etc.
The logic is that I know the car, i've already replaced the PCV system on it, alternator and rear suspension air bags. Any car I get will likely need them too. If I do the above tasks, the car should be "like new".
And ultimately it will be reliable and cheap over the next handful of years. It currently stands me about £6k after 2.3 years. That's currently not bad. If I spend another bit and keep the car another handful of years it will make for some good value driving. I will have gotten more than my fair share of learnings from it (good and bad).
It's a win/win really.. unless the engine work is prohibitively priced (i've heard some horror stories).
