I've got a leak somewhere on roof - i think.
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by PINBALL, Feb 13, 2019.
  1. PINBALL
    PINBALL Senior Member
    580
    48
    Jun 20, 2005
    East Grinstead
    Your Mercedes:
    124 E230 / 124 E220 /124 E280 /210 E320 CDI Wagons
    My E320 W210 Estate has had a leak in odd place namely the central courtesy lamps cluster just above rear view mirror.
    It only occurs when stationary and parked on slope with back higher than front, then when driving off it drips all over auto gear lever area.
    Won't leak on the move even in windy heavy rain conditions!
    Any ideas please?
  2. Blobcat
    Blobcat Moderator
    10,290
    1,076
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Do you have a sunroof?
    If so open it clean the drains and clean all the metal work that leads to the drains and polish it so the water doesn’t hang around.
    PINBALL likes this.
  3. ajlsl600
    ajlsl600 Senior Member
    2,029
    473
    Nov 18, 2013
    france
    Your Mercedes:
    clk3202001,sl6002003 with everything,A class 170cdi auto
    1st reply about right i think,unless no sunroof, in which case ,the mind boggles .....
  4. Blobcat
    Blobcat Moderator
    10,290
    1,076
    Your Mercedes:
    It's a 210 so the roof might have rusted through... :-(
    Frontstep and PINBALL like this.
  5. Wighty
    Wighty Senior Member
    5,191
    2,431
    Aug 4, 2016
    Your Mercedes:
    From the aerial shark fin at the back of the roof , if you have one ? Or top of the windscreen ?
    PINBALL likes this.
  6. ajlsl600
    2,029
    473
    Nov 18, 2013
    france
    Your Mercedes:
    think op says runs down near rvm?
  7. Wighty
    5,191
    2,431
    Aug 4, 2016
    Your Mercedes:
    I know , but the water must get in somewhere , even if the appearance of it is slightly delayed as the water travel before it drips out . Just suggesting things to check
    PINBALL likes this.
  8. Wighty
    5,191
    2,431
    Aug 4, 2016
    Your Mercedes:
    Does the screen wash supply for the rear wash wipe reservoir run through the roof area ?
    PINBALL likes this.
  9. OP
    PINBALL
    580
    48
    Jun 20, 2005
    East Grinstead
    Your Mercedes:
    Thanks for quick answers everyone.
    No sun roof or shark fin at rear, putting it down to maybe leading edge of rubber strip that holds windscreen maybe.
    Or thanks Wighty for suggestion that rear w / washer tube could be the problem.
    Wighty likes this.
  10. Blobcat
    Blobcat Moderator
    10,290
    1,076
    Your Mercedes:
    Has it ever had a new windscreen? Thinking the bonding hour might not be 100%
    Alternatively I remember when Mercedes did some rust repairs on mine they glued the rubbers to the doors to stop water getting behind them and rusting the metal out. Just wondering if water has got behind the windscreen rubber and done it’s worst...
    If you can peel it back at all and take a look, also if you can get a rag or something behind the seal you can tell if it’s wet or comes out reddish...
    PINBALL likes this.
  11. ajlsl600
    2,029
    473
    Nov 18, 2013
    france
    Your Mercedes:
    a bit of a mystery ..windscreen has to be prime suspect .. just read op 1st post it comes in when back higher than front !! and not when on the move. might look a mess ,but get some w/proof tape ,duct will do,tape along top of front screen to roof and 6 inch down sides ,see how that works out for a while
    PINBALL likes this.
  12. OP
    PINBALL
    580
    48
    Jun 20, 2005
    East Grinstead
    Your Mercedes:
    Great suggestions Blobcat, had car since 2015, and know previous owner had said he'd had a stone chip repaired on wndscreen, plus towing his caravan to south of france every year for the 10 years he had it.
    The leak 1st appeared 2 years ago starting teaspoonful & now more like a tablespoonful that takes around 5 miles to drain out when going round bends.
  13. Wighty
    5,191
    2,431
    Aug 4, 2016
    Your Mercedes:
    If it's an estate , any roof rails/strips that hide issues below them
    PINBALL likes this.
  14. Frontstep
    Frontstep Senior Member
    6,409
    465
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Another one for rust or screen.
  15. OP
    PINBALL
    580
    48
    Jun 20, 2005
    East Grinstead
    Your Mercedes:
    Great suggestion - many thanks.
    Meant to answer sooner but this website went off wed 13th evening, and pages or answers were unavailable.
  16. OP
    PINBALL
    580
    48
    Jun 20, 2005
    East Grinstead
    Your Mercedes:
    Only black side roof bars lower than central roof height, so will try some tape across top windscreen rubber & 6" down sides as suggested - thanks.
    If that fails then closer look at roof bars is next.
    Wighty likes this.
  17. Flyinspanner
    Flyinspanner Senior Member
    1,632
    339
    Aug 8, 2010
    Ruislip
    Your Mercedes:
    CL500 -W215, A140-W168
    Comma used to make a fluid called ‘Seek n seal’ great for windscreen seals, it worked by capillary action, was in a tin a bit like the old 3in1 oil tins. - worked a treat on my Scimitar.
    PINBALL likes this.
  18. Flyinspanner
    1,632
    339
    Aug 8, 2010
    Ruislip
    Your Mercedes:
  19. LostKiwi
    LostKiwi Senior Member
    15,603
    6,448
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    I've used Captain Tolley's creeping crack sealant (seriously that's its name) successfully in the past .
    Flyinspanner, Blobcat and PINBALL like this.
  20. ajlsl600
    2,029
    473
    Nov 18, 2013
    france
    Your Mercedes:
    ah,roof gutters,good chance they feed screen leak ,no?
Share This Page
