Jacking Pads
Discussion in 'Mercedes Goods on eBay' started by Moviestar, Jul 7, 2018.
  1. Moviestar
    Moviestar Member
    17
    3
    Mar 10, 2014
    Your Mercedes:
    W203 c-class
    malcolm210 likes this.
  2. Wighty
    Wighty Senior Member
    5,905
    3,131
    Aug 4, 2016
    Your Mercedes:
  3. Chrishazle
    Chrishazle Senior Member
    2,511
    380
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    S204 2008 C220CDI Elegance Estate Auto, 1993 Porsche 968 Tiptronic cabriolet
    I have those for my MB, not yet had reason to use them, but also tried ice hockey pucks on axle stands when I needed to get my 968 completely off the ground. Made the mistake of getting one side up first and onto the axle stands, wheels off, then was lifting the other side when the pucks allowed the whole car to slide sideways and off the axle stands onto the driveway.:shock::shock::shock:
    stwat and Wighty like this.
  4. Wighty
    5,905
    3,131
    Aug 4, 2016
    Your Mercedes:
    The axle stand pads have slots underneath that help keep them on the stand top . I bourght a really big jack to lift the car up on the diff or engine sump pad to try to stop any sideways movement
  5. Chrishazle
    2,511
    380
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    I think the biggest lesson was, if you need all 4 wheels off the ground, lift the front then the back, OK loosen the wheel nuts slightly before lifting but do not take the wheels off until the car is settled on all 4 axle stands! Lucky for me there's a big metal bar behind the 968 rear plastic bumper, and I had a second trolley jack to lift the car back up and release the other trolley jack which had jammed under the car.
    And Breathe!!
    Blobcat and Wighty like this.
  6. OP
    Moviestar
    Moviestar Member
    17
    3
    Mar 10, 2014
    Your Mercedes:
    W203 c-class
    Wighty likes this.
  7. Blobcat
    Blobcat Moderator
    12,305
    2,207
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    The 997 slipped off the low profile trolley jack on me as the castors jammed on the tarmac on the drive :-( crease in the outer sill which cost me a few £££'s to rectify.
  8. dermot dublin
    dermot dublin Senior Member
    150
    17
    Jul 24, 2011
    dublin
    Your Mercedes:
    c180 1998 1.8 faithful friend but now retired- e200 w210 2000 avant garde
    My engine sump pad is missing, any idea where i could get one.?
    car is 2004 w211. 1.8 kompressor e200
  9. Wighty
    5,905
    3,131
    Aug 4, 2016
    Your Mercedes:
    Either MB new or eBay secondhand ? buddy
    dermot dublin likes this.
  10. GLK
    GLK Senior Member
    3,106
    1,069
    Sep 19, 2014
    Bozeat, Northants
    Your Mercedes:
    A200 Avantgarde Special Edition Sports Coupé • C169
    Is there a type that fits between an axle stand top (3-ton ratchet type) and the standard rubber pad (body lift support point)?
    Will the U-shape axle stand top damage the rubber pad, if goes directly under it?
    I want to put car on four axle stands to paint calipers - will raise front, and then back, using jack under the front/rear axle central support points and stick axle stands under the body lift points on each side ... if that makes sense. I'll use pieces of wood to distribute weight for the central axle support points, but not for the rubber pads, hence the question.
  11. Wighty
    5,905
    3,131
    Aug 4, 2016
    Your Mercedes:
    There is such a pad and I have 2 of them bourght from eBay I tried to get another 2 a few weeks ago but couldn't find them again . I think they were advertised as fitting BMW's but also fitted MB in the small print . Hopefully someone can post a link for whoever is making them at the moment , they are very good .
    GLK likes this.
  12. Wighty
    5,905
    3,131
    Aug 4, 2016
    Your Mercedes:
    The first link by the OP is the eBay seller I bourght them off , maybe worth a message to him if you can't see the items in his shop
    GLK likes this.
  13. GLK
    GLK Senior Member
    3,106
    1,069
    Sep 19, 2014
    Bozeat, Northants
    Your Mercedes:
  14. jim2607
    jim2607 New Member
    Mar 16, 2015
    Guildford
    Your Mercedes:
    S211/2003/E500T
    Thanks for the shout on this OP, have bought one on your recommendation as wasnt aware they existed. Cheers!
  15. OP
    Moviestar
    Moviestar Member
    17
    3
    Mar 10, 2014
    Your Mercedes:
    W203 c-class
  16. PovertySpec
    PovertySpec Senior Member
    1,214
    155
    Mar 12, 2014
    Hampshire
    Your Mercedes:
    E220 CDi 07/57
    I'm still using ice hockey pucks, £1 a piece :)
  17. malcolm210
    malcolm210 Senior Member
    3,227
    385
    Aug 21, 2005
    So am I always good to find a double use for something cheap and available
  18. Chrishazle
    2,511
    380
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    See my post#3 above and beware!
  19. PovertySpec
    1,214
    155
    Mar 12, 2014
    Hampshire
    Your Mercedes:
    E220 CDi 07/57
    Have a look at post #1.
    It's an official regulation hockey puck with a rubber block glued to it. As are the others (except #13)
    One should always be careful when jacking any vehicle up as the jacks rarely lift straight.
  20. Chrishazle
    2,511
    380
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    After my hiccup with the 968 I bought those for the S204, they live in the boot of the car, but I've yet to have need to use them as bar 1 occasion the only times the wheels have been off the ground was at a garage. The one other occasion (wheel change at side of road) I used the car's own jack which is shaped to fit the jacking point. I'll try them IF I decide to change to my winter wheels this year (didn't bother last year), but it's so mild I'm still on my normal Eagle F1's.
Share This Page
