jacking points - MOT requirement?
SilverSaloon
w124/1994/om606
hi
as some may already know i'm restoring my 1985 107 SL.
i've done quite a bit of repair to the sills. unfortunatly, the jacking tube isnt the best.
at the moment i've created the jack point hole and welded the tube on etc and all looks OEM but i wouldnt completely trust the jack point tube to hold the car so i'd use a trolly jack further back.
i was thinking of just covering up the jack point hole and not having one - at the moment its there but i wouldnt want to use it.
can anyone confirm whether this is OK for the MOT etc...?
thanks
derek
Xtractorfan
S class
Jacking points are not a requirement for the mot, tho blanking it off completely may make a jobs worth investigate more.. These are normally covered with plastic caps so just glue it in permanently
As Xtractorfan, the main thing is that no rust is in the sills as these are part of the MOT
SilverSaloon
SilverSaloon
w124/1994/om606
there is no more rust - its all been cut away and a new sheet of thick steel welded in place. the R107 doesnt have plastic covers for the sills - the holes are just exposed.
