Exp21
- Dec 17, 2018
- Location
- Italy
- s204 C200 CDI Blue Efficiency MY2012, w245 B200 CDI Facelift
Hi everyone. I'm trying to find the proper way to install and torque to specs the two top nuts (jam nuts) of the new set of rear shocks for my B-class. Aftermarket shocks have two nuts instead of the MB original one. WIS says to torque to only 20 Nm. First question: is it possible only 20 Nm?
Second question: 20 Nm is referred to a single nut. But in the case of jam nuts, I read that the first nut has to be torqued to about 50% of the value, and then the second nut torqued to the full value (20 Nm) while holding the first nut. Is it the proper way?
Do you have knowledge about jam nuts? Thank you
