John Coker
SL 55. the comms pack was working fine until I turned off ignition ,then when I restarted the engine, the volume of the radio and sat nav had gone even tho the screens were ok and the cd screen showed ' no cd changer connected' with no volume. Left the car for an hour and all was well again but later when I turned off the ignition the same fault returned. Turning the ignition on & off in quick succession does not cure it but a time lag appears to do the trick!!!
