CrustyClam
- Jan 28, 2017
- Age
- 54
- Location
- Warrington
- ML63 2007
After some advice please. It's only happened once, but if it has I'm sure it's the beginning of something.
I got a real hesitation and judder (from standstill) when I put my foot to the floor. The engine was at a good temperature. The car is running great apart from this one instance. I have checked codes, nothing shows.
On my return journey I had the MB2 recording all the freeze frames. Fuel trims are good (that's good since the manifold and a leaking rocker cover have been replaced).
Googling it could be a coil on its way out. (I have a spare one in case, but not much use changing now as symptom has only occurred once)
I'm going to keep recording decent journey lengths which may give me the opportunity to capture useful freeze frames, and highlight an issue.
Any suggestions?
Any suggestions?
