i have a c class 51 plate it has a tiptronic gearbox the problem is it seems to jump into neutral when approaching a juction or roundabout it also seems to stay in gear ie second and the revs run high help
Hi Stevie, the plate is about £130 from MB and requires draining down of the Transmission to fit, so might as well change the fluid and filter at the same time, - the electrical connector (£20) too while you're there. Probably looking at about £250 to £300 from an indy or gearbox specialist.
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
