just bought a C180
WhiteC180
webs.com
94 C180 Elegance, Volvo V40 Estate (wifes)
Hiya all, have just purchased a 94 C180, and new to the site, so Hiya all.
secondly, when at lights etc the idle seems to rise and fall between 500/1200rpm, any ideas?
Could it just be a timing issue or more serious?
Cheers guys
W
WhiteC180
webs.com
Many thanks
Not only do you help out with photo's but also the serious stuff too! lol
cheers
Many thanks
cheers
You will soon find your way around,,just join in anywhere, we are lucky in that we have a very nice bunch of guys on here, must say that your car looks very clean:D:D
W
WhiteC180
webs.com
Cheers
The car in general is pretty decent, one or two minor points such as :
door retainer snapped on drivers door (£18 ebay)
Inner door sill trims missing on both front doors
rise and fall problem as described.
couple of minor rust bubbles on rear arch
but apart from that, not bad for a 15yr old, seen better, seen worse.
cheers for your help
W
WhiteC180
webs.com
If it is the vacum leak problem you described, is it an expensive repair?
Vacuum leaks are often just one of the small plastic pipes that have split or come off their mounting tube, they all need to be a tight fit, there are not many of them.
www.ckinsurance.co.uk
