Key Fob needed W140
Alcudia
S500 Coup Black, S280 Gold(ish)
Hi
Do i have to go to (gulp) a MB main dealer to get a new IR key for for my W140 s500??
If so - anyone know how much and what docs I need?? The car is imobile so carnt take that - will this be a problem??
Ta
Hi
Ta
In a nutshell, yes!!!
What is wrong with your existing key
A
Alcudia
The micro switch inside was very unreliable and eventually stopped all together - however i had previously cured the "constantly coming apart problem with a 2 part superglue - i have had to jugsaw my way in to expose the micro switch, which i have now re soldered: so it does now work. However i carnt see it lasting long as half the case is now missing and all the electronics exposed. Im going to try and inject epoxy to seal them - but i think the inevitable parting with huge wedge's of cash is on the way!!!
Why not buy one on Ebay with a good case and change the PCB over
A
Alcudia
Im pretty sure i would destroy the pcb when trying to get it out. This 2 pac superglue is something else. Its not readily available - trade only product. You put line on one side with a thick maker pen and then the glue on the other side, when they meet it sets instantly. Lets put it this way it will tear the wood of one side of a solid oak worktop (which i use it to join) rather than the glue give way!!! But for the few quid ill give it a go getting one on ebay. If the worst comes to the worst ill read the code with a IR learning tv remote!!
A
Alcudia
Pants - thats the TV remote idea up the spout. Ill get the dremmal out and get to work cutting the PCB free. All this for one 20p micro switch! well that and one idiot let loose with the superglue !!!
A
Alcudia
Has anyone EVER had one of these stolen?
A soldering iron is handy to cut plastic,,it will not damage the pcb
A
Alcudia
That is a real good suggestion!! Thank you.
A
Alcudia
Someone is selling these on ebay and giving the impression that once "sinc'd" i.e blip twice, turn key, turn back, start the fob bit will work with your car. Is this the truth or a load off bull droppings??
No truth at all otherwise all of these cars would get stolen "just like that"
A
Alcudia
Well you would still need the key to activate the ignition - but i thought as much as there site also contained a very long disclaimer re checking "reprogramming" etc.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
if you send the key to me I can fix it. I have a spare casing and parts.
jib
www.ckinsurance.co.uk
