Key problem possibly for Malcolm.
R W
Amble,Northumberland
2001 E320cdi/ Sclass 2012 350cdi
My 1998 210 has the electronic three button key fob. The key I was using, sometimes when you put the key into the ignition switch nothing happened, it did not unlocking the steering lock & so could not turn on ignition. Most times it worked ok but the malfunction slowly got more frequent. I tried using the spare key & it works perfect every time. So it is obviously a problem with the key.
Today I tried the original key again & it wont work at all. The buttons for locking & unlocking work perfect.
My question is, can it be repaired or do I need buy a new key.
Send it to me and I will see what I can do for you :D:D
R
R W
Malcolm.
It may be a few weeks before I get back to Uk as its the key for this car in Russia that is the problem. I will contact you for your address nearer the time I am expected back to Uk & post it to you.
R W
Fine and no problems
drdre78
london
mercedes c200 200
hi can check you key with camera and pushing buttons.sounds like EIS need replacing
Yes you can check the key for unlocking problems, but not for the key turning in the ignition switch
R
R W
Malcolm.
Got back today & the key you repaired for me works a treat.
Thanks a lot, I will ask the better half to forward payment.
Thanks/Regards
R W
Malcolm.
Thanks/Regards
R W
Thank you very much,,The little charge I make will not break the bank
R
R W
No, Not at all, I am very gratefull for your help.
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
This sounds like an excellent 'member to member' service offered by Malcolm, and I applaud his never ending helpfulness on this forum.
