Keyless Go - retrofit to W220?
mkg988
Essex
Is it possible to retrofit keyless go, or just the start/stop button function on a 2006 W220?
Thanks,
Martin
Yes you could retrofit the keyless go system,,you cannot just have a start stop button through security reason.
I have it on my SL it is one of the best extras
whitenemesis
CLS55 AMG '05
Not sure about your model but on the 203 it's a huge undertaking and will be very expensive. Even the most hardened Merc moders have said never again!
So, all is possible just depends how deep your pockets are! :)
It is only a £880 extra when new
whitenemesis
CLS55 AMG '05
Which is no real indicator of the retrofit costs! So much easier to instal when the car is being built. From a write-up I read this mod requires the removal of just about every trim part/panel.
I agree peter,,even all the door handles have to be changed, and the wiring to them. I know one firm who would never try again to do it, and I see that it has been dropped now and no longer on the list,,the same as on my car
M
mkg988
Essex
Okay, thanks for the advice, I suspect I won't bother with that particular mod. Although I would like to use the start/stop buuton on the gear shift, even if I do have to put the key in!
Maybe I'll just change the gear shift, so I have an extra button, that doesn't do anything.
Martin
tromppost
South East
s320
So that would take Ed China (wheel dealer mechanic bloke) about 1hr 20mins!!
