B
br1anstorm
When I bought my 1990 SEC560 a couple of years ago, it had only one key - which worked doors and ignition, but not the bootlock or cubbybox cover between the seats (ie I assume I only got the secondary key...). So the boot could only be locked or unlocked using the door/vacuum circuit.
Unaware, at the time, of MB's practice of providing primary and secondary keys, I asked my local independent MB garage to help. Instead of getting (as perhaps they should have done) a replacement primary key to fit all the existing and original locks, their solution was to change the bootlid lock barrel, for which of course I now have a separate key which operates that lock only. So my original key still won't open the boot; the new boot lock key doesn't fit any other lock on the car; and I still can't lock the cubby-box.
How can I simplify and sort out this inconvenience? Can I get a replacement bootlid lock barrel which matches the other original-spec locks, and a new key which then fits and operates all the locks (doors, ignition, boot and cubby)? And would this cost the proverbial arm and a leg?
br1anstorm
br1anstorm
