S202 200K (01 Y)
The usual poor running, flat spots , roughish idle , pinking, MAF RELATED ISSUES( changed recently) so I bobbed along to local indie( MercCare Pudsey ) for a squint. Very genuine & really helpful, no hard sell , listened to all I could describe.
Had a good few of these in lately, says he,so pulled of the air intake, wiped finger inside loads of oil floating around obviously clogging mas and leading to usual symptoms BUT DIAGNOSIS IS FAILING KOMPRESSOR UNIT!! Says this is all too common on this age of car & although units are now cheaper & available from Mercedes( £580+vat) previously £1100 +vat - exchange) and whatever labour -it seems to be a known & regular fault.
Any ideas ,help or advice appreciated.
Other owners beware could be you next!!
Mines just turned 70k by the way & I do tend to drive it hard (where permitted) There is a unit on e-bay £250 supposedly from a low mileage ,damaged car, no ancilliaries What do you think I would need?
Otherwise a great car so likely to grimace & stump up before it gets terminal.
