lambda sensor?
Legoman
just a quick question , does my car have one of these? coundnt see one visible on the exhaust system , mine has 2 x cat's . im just pre planning just incase the replacement of my rotor arm , dizzy cap and leads doesnt resolve the fault i described before . if it doesnt my next target items would be the coolant temp sensor , fuel regulator and if it has one the lamda sensor.
im tempted to do the coolant sensor anyway just to be on the safe side :)
L
Legoman
luders79
London
W210 estate
Hello,
I think from memory on a 124 if it has got a lambda probe the wires for it comes up through the floor under the drivers footwell carpet! where in connect to the main wiring loom.
Please correct me someone if i'm wrong!!
L
Legoman
well if thats the case mine would need two probes which to me seems unlikely to come up through floor , im gonna check under the car when im off work but im starting to think i havent got them due to age of the car. especially as on the picture/diagram with one on its clear as day , but on my blueprint one theres nothing there.
kth286
E320 Coupe 95
Legoman
What makes you think you have two cats ????????
You may have two silencer boxes.
I do not think cats were even mandatory for your car year, and therefore probably NIL lambda probes/sensors.
L
Legoman
i figured that the label on the engine suggested that (see pic above)as it says AMG M 104/3.4 - 24 KAT i figured that ment catalytic convertor as in german its spelt with a 'k'
