Leaking injector seals
Funkyboy
Liverpool
E250 w212 14 plate
Got signs of leaking injector seals on my 14 plate e250 on 67k is this normal at this mileage and is it a costly fix?
w204benz
2012 C200CDI AMG Sport
Is that with the OM651 engine? I found diesel around a couple of the injectors on mine a few months ago so I had all the seals replaced, but it does have over 120k on it. No idea if it's normal at 67k (assuming it's the same engine).
Parts were cheap. I have no idea what the labour rates are like in the UK, but I wouldn't imagine it would be too costly if you tackle it early enough.
F
Funkyboy
Liverpool
E250 w212 14 plate
Yes 0651 engine
w204benz
Yes 0651 engine
Then I suggest trying to source the plastic connectors that attach the fuel return line to the injectors before you start - apparently mine had become brittle and broke when the mechanic tried to remove them.
The dealer will happily sell you a new return line at some exorbitant price - and I was told fitting it may not be a quick job - but the connectors seem to be a common part and pretty easy to swap out.
Hopefully you don't have my luck and find out that every local supplier is sold out after they're broken!
