Leaking water into passenger footwell in w123 1984 coupe
pendphie
Registered
bromley
230 ce
Hello -i have a 1984 230 ce and there is water accumulation in the rear passenger footwell after heavy rain and i cannnot see the source. Anybody any ideas, or recommend somebody who knows about this and a solution.
Regards.
Phil
Hello and welcome
I’d check the under the window seals for rust, especially the bottom of the rear screen
aaronmcgrattan
Registered
W123/1982/230ce, W123/1985/300D
under front corner of front windscreen. same isue myself.
Motoman70
Abingdon
2006 sl350 3.5
I struggled with this for 12 months
I wouldn’t mind betting this is a blocked drain in the air in
Box for the heater
Exactly the same symptoms wet on the tunnel and sopping wet behind the rear passenger seat cost 100£ at garage to fix
