Led upgrades
jetski
Suffolk
RS 250 Megane
Hi guy's, when I got my 04 CLK the front map/interior light did not work so I replaced it with an led festoon type bulb only for it to stay on dimly all the time because of the lower voltage of the led, I was just wondering if anyone has found any led's that overcome this without putting in an inline resistor and also if I replaced the door puddle lights they would also be the same. Thanks
Miffy
Bromley, London
CLK 320 CAB Elegance C208
Not sure whats happening to yours, but LED festoons are 12v. I have them in my puddle lights and the boot. work as expected
I wonder in that position if the LED draws sufficient current to discharge the circuit that it is on
djheap22
Lancashire
CLK 2005 - W209 facelift; VW Golf MK1 Clipper
Is it not the fact a low voltage is applied to the circuit to check for bulb failure. Which on a normal bulb wont produce any light but LEDs will glow dimly.
I dont think the puddle lights would be the same, but even if they where you cant see them when the doors closed.
I have the same effect on myn but goes off with the key so no drain on battery.
Tel: 020 8863 9233
