curious
- Nov 17, 2008
- Only the Vito left! W639/1 OM646
OK, so I give up.
I've bled the brakes and, I've bled the brakes again. I've pushed litres through the system trying to get to the bottom of this. No air bubbles whatsoever yet the brake pedal on my Vito (W639) feels as if it's almost at the floor before it starts to bite.
I've cleaned up the calipers to the extent the MOT guy commented that they were all very well balanced left to right for a 12 year old Vito (only 100,000 miles).
The long pedal travel started after I replaced the pads one time. I probably shoved the brake pedal too far whilst bleeding and possibly caused problems with the master cylinder. I replaced the master cyclnder and bled with lots of little strokes with a helper. I've also tried bleeding with a Gunson pressure system. I've bled it with the engine running and without.
No air comes out whatsover, yet the pedal travel is longer than it used to be and too long for comfort.
I'm hoping someone can help me with this?
