- Feb 8, 2006
- Location
- Grange Moor
- R171 SLK280, Smart R451, Land Rover 110 County SW, 997 C2S, R1250 GSA TE 40th, CBR600FP
- Moderator
- #21
You should have kept that one…Ony Airmatic or ABC. Stick to the Airmatic. If the Suspension is flat when you go see a car, run away. A good Airmatic drops about 2-4mm/24hours on average and is normal. Also the Air Pump should only run for a few seconds after start-up, if it runs for extended periods or is really noisy could indicate a leak or a worn Pump.
I had a 2001 S500 and the pump gave way because the Air Feed Pipe between the Filter and Pump had split letting in unfiltered Air damaging the Pump. I replaced the Piston Ring and Cylinder along with a new Filter and fixed it myself at a total cost of about 80 quid.
Another weak point is the PSE Pump for the Central Locking and Soft Close etc. Mine stopped working because the Passages in the Valve assembly got blocked from the Carbon Vanes inside the Pump so it kept on blowing the Fuse to save the Pump from damage.
Again I cleaned it all out and reset the Vane clearances and it was sorted at no cost other than my time.
A lot of things can be rectified on the older w220 relatively cheap or DIY.
I think mine had most of the Extras:
200A LEATHER
205 OWNERS MANUAL AND SERVICE RECORD - ENGLISH
231 GARAGE DOOR OPENER
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
264A LEATHER SAFFRON
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
278 TELEPHONE PRE-INSTALLATION COMPL. D-NET
284 SELECTOR LEVER, WOOD
289 WOOD/LEATHER STEERING-WHEEL
352 COMAND
366U AZURITE BLUE - METALLIC
401 DELUXE FRONT SEATS WITH VENTILATION AND HEATING CO
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
596 HEAT INSULATING+IR REFLECTG.SAFETY GLASS ALL-ROUND
600 HEADLAMPS - CLEANING EQUIPMENT
617 XENON HEADLAMPS, LEFT-HAND TRAFFIC
673 HIGH-CAPACITY BATTERY
731 WOOD TRIM BURRED WALNUT ROOT
774 SHELL MODIFICATION FOR AMG-WHEELS
792 AMG-WHEELS 8X18 SQUEEZE-IN DEPTH 31 235/40 (S210)
800 N/A 813 LINGUATRONIC-GERMAN (VOICE OPERATION)
816 REMOTE CONTROL FOR RADIO /COMMAND (OMS) REAR PASS
819 CD CHANGER
872 REAR SEAT BENCH HEATING LEFT UND RIGHT
882 INTERIOR SAFEGUARD
883 POWER CLOSING SYSTEM
And sorry but I love showing off one car I should have kept - but tht what happens when someone offers you twice as much as what you paid for it! STUPID!!!
Good luck with your search.......
